I have an 06 gator hpx gas that has no power, won’t climb any sort of incline, will bog down and die. Replace plugs, coils, fuel pump and fuel filter. Also cleaned carb. Still falls on its face. Any info is appreciated. Thanks
Welcome,
If you are curious as to the DOM of your Gator, look under John Deere Gator Forums, click on the first discussion area
What Year Is My Gator then click on
Model Year Lookup Table If your PIN is not there see your dealership.
There are several online Deere part warehouses such as
Green Farm Parts (use code GTT for discount) or
Green Parts Store (use code TTWT for free shipping). These online companies can often provide better pricing than local dealerships.
Additionally, please check out
@SuperATV for aftermarket accessories for your Gator:
SuperATV
Manuals
Additionally, use the robust
Search Community function on the forum, there is a great deal of information available through this function.
Finally please review how to use this forum, click on
FAQ from here you will learn how to post, add a profile, send conversations (messages to other members), add photo, etc.
Thank you, Enjoy your Gator !
