1 - 2 of 2 Posts
I just bought a new project 6x4 and it seems to be pretty decent, just seems to have sat more than anything.
It starts and runs, but the radiator was really low. Filled it and I have a leak at the water pump.
The thing is when I look at the parts list on the online catalog, I see the outer cover and the pump itself, but it looks like there is a spacer between the pump and the engine block. The leak I have appears to be between the black and spacer and I cannot see that spacer and gasket on either the water pump diagram or the head/crankcase diagram.
Is it just using the same gasket as #15 on the water pump diagram?
Anyone have insight on what gasket I need? I am thinking of just replacing the gaskets to see if it fixes the issue.
Automotive tire Motor vehicle Vehicle Automotive exterior Rim
Discussion Starter · #2 ·
So, for those that may look at this in the future, it is not a spacer. The piece under the water pump is the crankcase cover. So, if you have a water leak like me in that spot, you are looking at having to replace the the crankcase cover gasket.
1 - 2 of 2 Posts
