1 - 2 of 2 Posts
Recently purchased this and it want to grind when shifting into gear. How do I fix this, difficult?
Spend 10 minutes searching and you'll find this is a somewhat common issue usually due to idle speed too high (simple fix) and more likely a primary clutch issue.
It doesn't really matter which model, they all use the same general type of primary and secondary clutches (CVT).
Just one example: https://www.gatorforums.net/forum/gator-general-discussion/16185-grinding.html
If you're uncertain how they work, suggest you watch a few videos on their operation.
Also suggest you purchase a workshop manual if you plan of doing your own repairs.
Does it shift easily when the engine is off?
1 - 2 of 2 Posts
