I have a 2001 6x4 Gator (gas) and need some guidance. It sometimes shuts off while driving for no apparent reason, but mostly when coming to a stop. I looked at the fuel filter when it shuts off on its own. The fuel filter appears empty when it does this. Also, from time to time, it will not stop when letting off gas, it still goes forward even after depressing brake pedal hard . The brakes work fine. I usually have to kill it with the ignition switch when it does this. It’s rare when it does it, but it’s scary. It seems to do it when it’s cold outside. It doesn’t matter if it’s cold or warm outside when it shuts off while driving or coming to a stop. The fuel filter was replaced but still have issue. Could it be fuel pump or is it something else? Is it one issue or possibly two separate issues? I’ve seen on the forum that it could also be a clogged screen filter in fuel tank too? Thanks!!
