Hi Folks,
I have a 2003 Gator4x6 diesel that won't start. I went through months of weak starts, even with a new battery, now zero.
The parts are cheap so I replaced the relay to the solenoid signal cable and the ignition switch. The starter/solenoid work great out of the gator.
There is no voltage to the signal wire. The relay was replaced.
My feeling is that there is a fuse, maybe something inline, upstream of this that I'm missing. There's no fuse panel I can find. When I turn the key I get lights on the panel but no crank.
Any advice of how to get juice to the signal wire?
kevin
kevin
