1 - 2 of 2 Posts
Hello, I tried searching but could not find anything and I admit I am asking before I look in depth this weekend.
I just got a 2004 Gator HPX 4x4 Diesel. This is back then they had a manual shifter to go from 2 wheel to AWD. So there are a pull under the dash to engage AWD.
That level does not want to move at all. I will jack it up and review all connections and make sure everything is greased if I can get it to move.
Has anyone had this happen before or have any tips? Thank you for your help in advance.
Thank you,
Gordon Mann
Could be front gearbox is damaged.
if seals are gone around axle shaft, probable got water inside
pull gearbox out to fix...
1 - 2 of 2 Posts
