So last weekend my gator was running fine then it turned off and would not start! I've replaced the fuel pump and filter and still the same thing! I checked the fuses all good ! I have a spark checker on the plug and I have spark! I sprayed a little ether and it started but died any help would be great!
Did you check fuel pressure before replacing pump?
I don’t have the technical manual for your model, but this is the manual that provides wiring diagrams.
It might be worth investing in one if DIY. It might have saved you from replacing parts unnecessarily in the future.
Ok so I do not have power to the fuel pump! There is a yellow and black wire hooked up to it? Where does the yellow wire go to ? I know that it is power?does it go to a relay or something??
It seems Deere often use’s yellow/black as switched power for accessories, although I’m not certain on your HPX
