I have a 2004 HPX that does not have the ROPS roll bar installed. I found one locally on Craigslist for a very good price (I believe it is Deere Part #BM24611 or Model #M0HX0PA), and would like to install it on my Gator. Before I buy, I want to make sure it fits and no major modifications are required (I know I need to cut holes in my front fenders).
I can't tell how the rear end of the roll bar mounts to the frame of the Gator. Does anyone know if there are any specific mounts that I need to install on the Gator before adding the ROPS? I can't find much here or elsewhere online regarding installation instructions.
The brackets on the ROPS look like they mount perpendicular to the frame, but I don't see where it bolts on. Are there additional brackets for the frame?
Anyone have some close-up pictures they can share showing the front and rear mounting points?
Thanks in advance, any assistance is greatly appreciated.
ElkHunter
I pulled one from my roller. It should come with hardware to install. Big bolts & washers. Should only have to cut holes into the fenders! When you set the cage on the gator you'll see where the bolt holes line up behind the seats.
