1 - 2 of 2 Posts
My 2007 Gator TX is having difficulties engaging. Engine starts fine, and idles well, but when I shift in gear, either forward or reverse, nothing happens unless i rev the engine and then it "slams" into gear. Drives fine after that until i go to neutral and the same happens again when i shift. Is it adjustable? Rebuildable? or best to just replace? JD dealer priced a new one at $650!!! Advice or direction? Thank you! (PS: I use mine frequently)
Do a search on here and you’ll find 6,432 posts pertaining to clutch or shifting issues. Try some of the recommendations by Bradhill and report back what you find.
It’s well documented but will require some reading on your part.
1 - 2 of 2 Posts
