1 - 2 of 2 Posts
I recently lost power to the fuel pump. Pump works when jumpered, but no voltage on connector when ignition turned on. When it failed during a start attempt, noticed warning lights (not oil pressure light) were flickering and pump was trying to run. Then lights went out and pump stopped running. Checked all 8 fuses under driver's side dash and all good. I don't have a wiring diagram. Is there a fuel pump relay that could have failed and if so where is it located for this model? Thanks
1 - 2 of 2 Posts
