41 - 41 of 41 Posts
Discussion Starter #41
Hello again,
Still trying to figure this all out . . . my Rav4 and Toyota Tundra have Toyo Tires and they have served me well for many years. So are there any thoughts mounting a Toyo tire like this one:
The 205/75R15 Toyo Extensa A/S has a diameter of 27.1", a width of 7.8", mounts on a 15" rim and has 766 revolutions per mile. It weighs 24 lbs. has a max load of 1598 lbs. a maximum air pressure of 44 psi, a tread depth of 11.7/32" and should be used on a rim width of 5-7"
on this wheel:
Specs:
Size:15" Rim Width:6" Finish: Machined; Bolt Pattern:5 on 4.5" Center Hole Dia.: 3.19" Load Capacity:2150lbsWheel Offset:0mmCenter Cap Size:3.19"Tire Size:225/75-15 and 205/75-15Back Spacing:3 1/2"Lead Time Applies if Assembly: Up to 4 Business Days Construction: Aluminum PSI Rating:60 PSIColor:BlackStyle:T08
Thanks to all for your patience with me . . . BTW, several online tire dealerships I contacted were not willing to help with my mounting fitment questions AS SOON as I mentioned my vehicle was a JD Gator??
FredSG
41 - 41 of 41 Posts
