1 - 14 of 14 Posts
I recently purchased a 2012 825i at auction. The machine has 2900 hours. The engine is running rough and has a knock (or a tick, not sure I know the difference). I am going to list what I have done to diagnose the problem and I am looking for suggestions on what else to do before pulling the motor and opening it up. I started off by changing all the fluids. No noticable shavings in the oil. I also drained and replaced the gasoline. I have pressure tested the fuel pump, which is a little below spec (40 psi). I have tested resistance on all the coils. The resistance is the same for all, although I can't find a spec to compare it to. I replaced the spark plugs. I have done a compression test on all three cylinders. They are all at 100 psi, give or take a few. I believe this is a low, but that could also be my compression tester. I have checked the timing belt. It is in time and the belt looks to be in good shape. I also did a leak down test on the cylinders and only had small amounts of air escaping (well within tolerance) from the dipstick tube. I have never worked on a DOHC motor before, but I have rebuilt other types of motors. I have a copy of the service manual. Any suggestions on testing before I dig into it?
What were the leakdown test results?
100 PSI compression seems low as for some reason 170 PSI sticks in my mind, but I could be way off.
Have you checked the valve lash? In the past some owners found the valve lash too tight causing an issue.
Also check your spark plug wires real good.
Good luck!
Leak down results were right around 15% and were pretty much the same for all three. Would valve lash being too tight cause a tick or a knock? I havent checked it, but will as I start to dig into it. Fortunately this is gator number two, so I still have something to drive around!
I was thinking the low compression numbers.
Knock sounds like a bearing issue.
Tick is usually associated with too much valve lash.
And I got a different compression tester. Gonna test again to see if the cylinders are low or if the tester is bad.
Discussion Starter #8
Finally got to pulling the engine to have a look and thought it might help someone to list what issues I have found. First issue - valve lash on the intake on cylinder 3 was too tight (2 thousandths, spec is 8 I believe). Otherwise all valve lash within spec. Not sure how the valve lash on the intake side could have gotten tighter, but I also remember reading somewhere that some of these engines seem to come off the assembly line with valve lash out of spec. I really dont think that was causing my issue. Issue 2 - one of the rod bearings was toasted and in turn overheated the bottom of the piston rod and scarred up the crankshaft. This is pretty clearly a problem. Since it is now broken down all the way I will be rebuilding and replacing wearable parts. The motor has 3000 hours on it and could use a refresh anyway. Surprisingly everything else looks to be in good shape and all other parts of the motor are in spec and look quite good. Now off to john deere to buy a bunch of parts!
Can the crank be reground? Pictures of the issue/damage would be nice.
Keep us posted on the progress.
Discussion Starter #10
I suppose I could get the crankshaft turned. Wouldnt I need a thicker bearing to compensate? I had planned on buying a new crankshaft. I dont really want to, but I bought the machine at auction and have quite a bit of margin on it before my wife complains. I attached the pics of the crankshaft section that got scored as well as the worn bearing. You can see on ofthe oil holes has filled in with metal shavings. Plenty of those in the oil pan when I opened it up.
If your margin allows, go to Power Sports Nation in Norfolk Nebraska they have fully rebuilt engines for the 825.
Discussion Starter #14
Parts I can get (at least have been able to so far) I just have to get them from my local deere dealer at deere prices. Lots green in my barn besides gators, so I know them and some of their mechanics/parts guys a little too well.
1 - 14 of 14 Posts
