John Deere adds a pair of midsize side-by-sides which includes a new four-seat UTV as part of its Crossover Utility Vehicle (XUV) family. The XUV 550 and 550 S4 use a smaller engine than the John Deere Gator XUV 825i that was introduced in 2010, and represent an entry into the JD family of SxS that won’t break the bank.
The new 550 series uses an air-cooled 570cc V-Twin engine. John Deere engineers use a carburetor to deliver fuel and the mill generates a claimed 16 HP and 28.6 lb-ft. A CVT transmission utilizes High, Low, Neutral and Reverse with 2WD and 4WD. It uses a limited-slip front differential which is engaged with a lever. The rear differential is unlocked to minimize wear and tear on the ground surface, but can be locked mechanically.
By JC Hilderbrand
Continue Reading @ 2012 John Deere Gator XUV 550 S4 First Look - Motorcycle USA
