Hey there, so i just bought a 550 s4 put a brand new battery in it and turn the key and nothing is there a trouble shoot on what i am missing nothing happens it’s weird no lights nothing on the dash where should i look i check the fuses already they are fine what’s the next thing i should check
thank you
Have you tested the key switch?
So what did the voltage read at the switch? How does it compare to the battery? Don't assume they are the same as there can be a voltage drop across the wire.
Many times a voltage drop test is a better test method than checking static voltage.
Only need one strand of the copper wire to register battery voltage during static test, but apply a load and the single wire will exhibit a voltage drop. I've found "voltage drop test" to be very helpful in pinpointing electrical issues.
