hello everyone,
im having some issues with my 825i. the front diff seems to be locked in 4wd. the switch changes nothing i tried going in reverse and froward. neutral with cycling switch. i even disconnected the solenoid and the 4wd wont disengage. please help
hello everyone,
Here is some information on the Theory of Operation and testing for the 4WD switch and solenoid.
4WD Switch
4WD Solenoid
Additionally, as you may know there is common condition with Gators that is referred to as “wedging “ see screenshot below.
Here is a link to the Operators Manual for the 825i. http://manuals.deere.com/omview/OMM173973_19/?tM=
Below you will find a screenshot from the above Manual that discusses Wedging.
Finally below is a link to a OEM Technical Manual for the 825i. These Manuals are invaluable to any Gator Owners.
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/113028381111
If you have completed all testing without finding the problem , there maybe an issue with the “roller cage” in the front differential. These cages are made of plastic and are known to crack.
Please report back with your findings and good luck!
I am having a similar issue with my 2011 855D. I was going up a grassy slope and wheels starting spinning and I pushed the 4WD button while moving. It seemed to work then starting clunking and slipping. I punched the button off and when I got to top of hill everything seems to work fine. What did I do wrong?
Is the 4WD system operational now?
