No, about all you can do is change the jet. Deere has a high altitude jet available.
Why do you want to adjust the carb.? If your fouling plugs or if you "think" the engine is running rich check for a head gasket leak. Those engines had a bad habit of blowing the gaskets. The new/revised gaskets are much better than the original.
How do I get at the idle adjustment on my 2012 550 gator.
I lift u the bed and don’t see anywhere.
Thinking I have to remove some covers.
If you’re trying to lower the idle in a attempt to shift gears, your efforts will sadly be futile.
