1 - 9 of 9 Posts
Friends,
I’ve purchased my first Gator— 2013 825i. Upgrading from a Kubota RTV500, the Gator is a beast!
It’s only problem is the parking brake. It doesn’t work at all. Cable is good. Fluid level looks good. Seller said he thought it was something in the transmission. From my reading, it looks like I may need a new parking brake assembly. Part number I’m seeing is AM148453. Part cost is fairly high ($400) so I’m hesitant to buy without some insights from others. Anyone tried to replace this before? It is a DIY project?
Second question. My 2013 825i has the silver wheels. Anyone tried spray painting these black? My Gator is the olive color and the black wheels seems to look better on these. I’m thinking about removing the wheels from the gator, taping off the tires, center wheel cover, and lug nuts, and painting the wheels using a flat or glossy black from rusteoleum. Anyone tried this before?
As always, thanks...
Check if over 6 clicks on brake lever the brake disc are worn or burnt. When you set the brake it also locks the differential lock ,so both cables should have tension on when set ,to not only set brake disc but also set the differential lock to lock. guick way is raise machine and set brake and check if lever on transmission is applying.
@jd772 as always, thank you for your technical advise!
My first though is I think it's a mistake. Invariably, the paint/powder coat whatever will chip and look like hell. I'd be patient and follow CraigsList for the black equivalent of what you have as Deere offered them in black as well as silver alloy. Tractorhouse is another good source. Remember the size - 14" !! Good luck. Craig
I too have considered painting my silver wheels, however I’m concerned with long term results.
I fear the paint will chip and flake off, in the not so distant future. Thus creating a total mess.
I checked with a local powder coating shop who offers a couple different types of coating, one of which was described as a “industrial coating” that would offer better long term results.
Also a important piece of their process is dipping/soaking the wheel in a solution that would allow better coating adhesion to the surface,as these wheels have a clear coating of sorts to protect the surface of the wheel.
This is why I believe any attempt to paint the wheel, without applying this solution would be futile at best.
The cost quoted to me for the “industrial coating” to 4 wheels was around $300.00
I’m in total decision paralysis on this one....
Here's a before and after I painted my wheels... I love the result. Not sure this was the best approach, but I cleaned and very lightly sanded the wheels and then sprayed with glossy rustoleum pro spray paint. I'd do it again.
Nice, please keep us updated!
1 - 9 of 9 Posts
