2016 XUV 560 runs good at fast speeds but when you slow it down it fouls up as if the choke is stuck. Plugs have been changed several times and are black. This machine only has 80 hours on it.
I would go with Dane/s suggestion. It may or may not miss, depending on where the the gasket failed. the 550's were notorious for blown head gaskets, even with low hours. I believe it is the same engine in the 560
