I also had 3 shocks replaced under warranty Feb 2017. The service manager said JD does everything as cheap as they can, and the leaking shocks are on the top of the list. I had 3 replaced, should have sprayed wd 40 on the 4th to get them all replaced. If they go out after warranty, Ill look to an aftermarket assembly as there is no way Ill buy known JD replacement junk.
As new in July in 2016, off the delivery truck the parking brake (more junk) would not unlatch, so could not even drive it when delivered, back to the dealer before the ink was dry on the check. The parking breake is has a cheesy cam and gear/lever system that is activated/deactivated by a cheap spring. If the spring cant release the cog, your stuck. Another cheap poor design.
Last you might want to consider adding LED motorcycle license plate lights to the gear and 4wd console. They were a pain to install and wire as the wires were tiny. I found a connector tucked under the speedo that you can use for power that as soon as the ignition key is on the lights come on. They are always on, but no power draw at all. So now if dark out you can see where the gear shift levers are and what gear they are in.
Ok this is the last. I also went on amazon and found a 3200 lumen led off road head light which I highly recommend as the oem headlights are junk. The lights are 4 inch rectangular 30 degree flood I think and about 35 bucks. A back lit toggle switch is about 12 bucks and wire harness.
Took a lot of time to figure how to take things apart, route wires for the lights, but the results are worth it and saved $700 over using JD Hella lights.
Adding small led red, tail lights next.
Overall a pretty good machine, but don't have much space to us it to really have fun with it.
Enjoy.
