First let me say this is my first post to the forum. I have gone through all 11 pages here and no topics relating to my problem. That being said, I shall also say that John Deere manuals suck! Nowhere in the manual does it tell you what is wrong when one of these lights is on and flashing. It only says that diagnostics is required. Take to dealer.
Now to my problem. Hope someone else here has had the issue and has an answer.
Engine is idling at 3 to 4 hundred rpm and at times will stall. If I press on the accelerator peddle it will idle up but as soon as I release, it's back down to the 3 to 4. In addition to that there are 2 indicator (warning) lights on. The one looks like a crankcase with an ! in the middle and it is flashing. To the right of that is a yellow triangle with an ! in the middle. It is not flashing. These lights come on immediately when I turn on the key and remain on after startup. Any help would be greatly appreciated. My dealer is 50 miles away. Long trip should this be something simple that I can fix. By the way, I did call them. They said bring it in. lmao Thanks, OT
PS: Things that I have checked; fuses, coolant, oil, air cleaner.
While the owners manual might not cover the desired information, the Technical Manual will cover the fault codes and diagnostic tree. (Based on Technical Manuals I've used, but haven't seen the one on this model).
The correct Manuals for your machine can be found here: Manuals
Find the correct manual using your SN (and not model year) and purchase from wherever you want. With manual in hand, you'll have the extra bonus of being able to help other members who need technical information.
Example of what the link above returns after entering the model number.
Reactions: Bradhill
Post 3 is a viable option if nobody responds.
Will you return with your solution or be like the others and ghost the thread after asking for help?
hopefully some will share their experience.
