The Gator uses a belt and variable pulley system to connect the engine and transmission. There is a primary clutch on the engine. It is operated by centrifugal force. As the engine rpm's increase the sides of the clutch/pulley come together to grab the belt. When the engine is at idle it opens completely allowing the belt to go loose and no power is transmitted.
In the rear is the secondary clutch which is attached to the input shaft of the transmission. It's side plates are normally close together forcing the belt to be near the top. As you drive and more torque is applied the sides of the clutch get forced apart against spring tension.
Those two clutches form a constantly variable transmission. If the clutches don't operate properly it can bog the engine down. Sort of like driving slow in a car in 1st gear and suddenly dropping it into 5th.
Will you be fixing this yourself or taking it to the dealer?
