1 - 1 of 1 Posts
I found your site liked it and signed up. First post on the little Kawasaki twin is to clean the throttle body! Take the four nuts off, pull the body back, loosen and remove the long bolt studs, remove and spray with carb cleaner. Then clean your air filter and repipe a snorkel higher in cab. Worst air cleaner design ever! I'll bet this cleaning will fix most rough idle problems. Thanks
1 - 1 of 1 Posts
