2006 620i Gator I’m having an issue with no spark at the plugs. I get 9.5 volts to the coils in the acc/prestart key position and 12.55 at the battery bu no spark. Any ideas? Second issue is I’m finding $250 for the fuel pump AM136232 and no longer made. Any ideas on an equivalent? Thanks.
Plug the part number + "aftermarket" into your favorite search engine. That might produce results.
Are you certain the fuel pump is getting the required voltage?
Gator wiring termination isn't always the most robust so it's not uncommon to find corrosion at any termination point including inside the fuse block.
