New to this forum...I have a 620i that has a problem running. when starting, it will idle perfectly for about 4 or 5 seconds, then stalls. When you press the gas pedal, the engine revs uop then stalls. If I pump the pedal the engine will rev up then stall unless you keep pumping the pedal.
Have changed the gas filter, air filter, oil filter, installed new plugs. No help there. I do not get any error codes at all.
Any ideas I can try?
Don
Don
