Hello,
I have a 2007 620i xuv that has no power to lights, dash lights, or starting circuit. Battery is good. have 12 volts going to the ignition switch on red wire in the off position when i turn key to run position 12 volts goes away and nothing on any other wire. can find fuseable link. checked all fuses. do not have schematics. shooting blind here. any advice would be appreciated
By any chance did y’all figure out the issue to this? I have a 2008 620i giving me the same problem
Unfortunately this forum could benefit from it's members following up and posting their resolution. Hopefully you will change this behavior and post what you uncover.
