As the title says I have a 625I that is a crank no start. Oil level is fine, I checked the fuel and made sure the filter wasn't clogged. Pulled the plugs they were soaked in fuel so I check spark and have spark. Anyone have any idea what this could be or that has seen this problem before? It sounds like it's cranking faster then normal did a compression test on one of the cylinders had 125. Didn't check the other cylinder yet. I'm not getting any pops or backfiring of signs it's even trying to start.
I have an 825i gator 1180 miles on it having a real hard time getting it out of low range shifts fine through all the gears just won't come out of low when shifted into low
Responded to your other post.
