I have a 1999 6x4 & the primary clutch is stuck in the full throttle position (expanded). Is there a way to get it back or how do I get it off to work on it? There are a few bolts on outside & a plastic cover over the center of the clutch thx for any help
There is a special bolt that screws into the center of the primary clutch that will pop the clutch off the main shaft .There are two lenghts of bolts one is JD813-1 and the longer one is JDG164-1 .Most dealers will say the first number is the only one however I learned the hard way that some require the longer (second bolt )
The sheave expanded is the idle position. It should open enough at idle that it does not grab the belt.
I'm sorry that I don't know the thread size?
