First, thanks xcopterdoc for the bed actuator information. I know you'll see this and I thought starting a new thread for a temperature issue might help others if needed. when starting my '97 6x4 diesel gator the cooling fan comes on right away along with the dash indicator light, I have coolant
. I assume I just need a new temp switch but before spending $80 the electrical diagram shows a B1 radiator core temp switch that when closed should allow the cooling fan to run but there is also a B2 engine coolant temp switch that lights up the H4 engine coolant light. Are both failed or does the B2 coolant switch close the B1 core switch but is not shown in the schematic? Apparently I have not memorized the wiring diagram
