Hi. New to the forum and in need of some help. I have a 6X4 Gator, maybe 8 years old. Was having problems with grinding while putting it in gear. Found the issue was the primary clutch and replaced that. All good there now, but seems that the machine is now somehow "stuck" in neutral. Shift level position was in forward, but machine rolled fine, leading me to believe it is actually in neutral. I suspect that the shift lever got jammed hard trying to force it into gear when the clutch wasn't working right. Now it seems jammed in the transmission. I disconnected the shift linkage -- no problem there. But shift lever won't budge. Any ideas???
