I have a John Deere 6 x 4 gator year unknown won’t come out of four-wheel-drive very hard to steer just wants to push the front end is there a fuse that I should look at or any other kind of knowledge from anybody… Thanks in advance
Welcome,
The 6x4, does not have front wheel assist or - 4wheel drive. Suggest you read below and look a Operators Manual for your 6x4.
By nature, the drive wheels will push you through the corners, suggest you add weight to the front of the Gator and use the Search Community function as described below.
If you are curious as to the DOM of your Gator, look under John Deere Gator Forums, click on the first discussion area
What Year Is My Gator then click on
Model Year Lookup Table If your PIN is not there see your dealership.
There are several online Deere part warehouses such as
Green Farm Parts (use code GTT for discount) or
Green Parts Store (use code TTWT for free shipping). These online companies can often provide better pricing than local dealerships.
Additionally, please check out
@SuperATV for aftermarket accessories for your Gator:
SuperATV
Manuals
Additionally, use the robust
Search Community function on the forum, there is a great deal of information available through this function.
Finally please review how to use this forum, click on
FAQ from here you will learn how to post, add a profile, send conversations (messages to other members), add photo, etc.
Thank you, Enjoy your Gator !
