Long shot... Is the solenoid still receiving power? Could happen when electrical contacts weld together. Remove wire to solenoid and try backing up several times going more than 20 feet.
not sure if you have had success with this or not, but i had the same issue and unfortunately, ran the gator for some time with the diff locked and didn't know it. jacked up the back end and ran it forward and reverse, both by motor and by hand. Eventually, the diff lock released, Tested again by applying the brake and the diff lock lever to find it was all working again as expected. hope this helps!
