1 - 2 of 2 Posts
Just wanted to put this out there for the guys that want to lift or even just level their machines on a budget.
I could not justify a $200 kit personally to level my 825i. I just wanted the machine to have a bit more clearance on the front and for it to sit closer to level rather than the raked look.
So here is the morel of the story.
I used a piece of 2" sch80 steel pipe as a spacer. I pulled the piece of pipe out of the scrap pile, so I have well... zero dollars into it. You can purchase a nipple for under $10 if you want to do this yourself.
13269
13272
Compressed the spring, pulled the retainer, loosen the spring, drop the cut spacer on the shock, re-assemble.
I cut the pieces of pipe at 1.5" as that was the height that I was shooting for.
Before: After:
13266
13265
Took me about 2 hours start to finish and it leveling it nicely in my opinion.
After install:
13270
Looks great!
1 - 2 of 2 Posts
