I have a 2012 825i. It has about 4400 miles and an unknown number of hours. Top speed is only 30MPH. The belt looks good visually but I plan to replace it just in case it's the culprit. Based on a review of the forum, I suspect my clutch is the problem. The machine sounds fairly rough, even idling. I took the attached video of the belt while idling. Does this look normal? It doesn't appear smooth at all. I've already emailed with the Clutch Doc and think I should have the clutch rebuilt but I wanted to check her too.
Thanks!
Cody
There is a minimum width specification for the belt and the width must be uniform throughout its length. Unfortunately I don't know what it is for your model, but I'm certain someone else will be able to provide.
Did you resolve your issue? Care to report the details?
