1 - 18 of 18 Posts
Hello, I'm to the forum.
I have done a lot of reading and searching on this forum, others and the web before joining and asking a question. I have read about the problems others are having, but haven't seen any that describe exactly what I'm looking for.
Let me start: 2016 825i
108 hours (102 hrs. When I purchased)
I'm the 3rd owner.
I purchased it in March 2019. This one is the first one I have ever driven, so I was unfamiliar with the fuel pump noise when you turned the key on. Well after driving it some I noticed that if you don't wait for the fuel pump to pump up and you start the engine, it will run with a miss. I don't know if it's 1 cylinder or 2 that's missing. One day I switched it on and waited for the fuel pump to pump up, started it and it ran fine. Them another time I waited started it , it ran fine and after 10 minutes or so it started skipping again. Switching it off and restarting didn't solve the problem. I let it sit for 30 minutes or so restarted and it ran fine. Today I was doing some spraying with it and it ran for about and hour, them started missing and I was wondering if it was going to have enough power to make it back to the trailer.
I haven't got in to diagnosing the problem yet. Thought I would check on some of things I've read.
Which cylinders missing, Plug wires, Injectors, fuel pump, fuel regulator, coils, Etc
What gets me is it misses if you don't wait on fuel pump to pump up (go silent)
Thanks, Byard
When you turn on the key it powers a relay so the pump runs to build pressure. it take 50 psi to open injectors and start . if pump is getting weak it will be hard starting . a quick way turn key on and off a couple times build pressure and see if starts easier. you said it was also missing or even a miss at start. it probably has low fuel pressure. you can check hooking in a tee to a pressure gauge after fuel filter. cycle key and watch pressure. also see if regulator is holding after relay cycle off. When was the last time fuel filter been changed, they collect a lot of water from the gas. Check the spark plugs . remove cover and clean dust around boots and remove wires , look to make sure wires ok. they can burn a small hole at bottom end causing a miss or hard starting issue. when you remove spark plugs look at how they look , clean burn white or even tan or black deposit which could be a bad injector. It does not show any check light on ? With that low of hours I would start by changing fuel filter. .
Thanks jd772,
like I said, I really haven't tried anything to trouble shoot. As far as starting, it will bust right off if you immediately turn the key to start or wait for the fuel pump to build pressure. It starts fine. It just misses if you don't wait on fuel pump to turn off.
I'll check a few things today and check in tonight.
Sounds ok it needs to cycle fuel pump to build the pressure to open injectors, it is only 3 cylinders not like a auto with 6 or 8 to crank and start
Update: I know I haven't posted in a while but been very busy.
A few weeks ago I pulled all plugs, they looked fine.
Plug wires are fine, no dust, dirt or debris. Heck it's only been washed 1 time.
But, a few days ago I ran it a few minutes and the miss/skip started. I took a long screwdriver and placed against each injector and handle end to my ear (to use as a stethoscope) The number three injector was not making the clicking sound as the other two were so, I took the tip of the screwdriver and tapped the reddish color part of the injector and the miss went away.
Yesterday after driving a few minutes the miss started again. Again it was the #3 injector, again I tapped injector and miss stopped. While probing with the screwdriver tip I did notice the injector moved a little. Almost like it rotated and clicked into a notch.
Today I used the gator right much and not once did it develop a miss.
Discussion Starter · #7 ·
Update: gator was used about all this past Saturday while preparing for upcoming deer season. I actually jumped on it and forgot to let the fuel pump to pump up several times and it started and ran just fine.(in the past it would miss...sometimes)
Is there a possibility that the injector wasn't seated probably. When installing do they snap or lock into place. Like I said when I was fiddling with the injector it turned slightly and clicked or snapped into place.
Thanks
The only snap or lock would be the clip that holds the injector to the rail. The o rings seal . The electrical plugs in to injector with a wire clip that locks in to hold electrical connector.
Thanks jd772,
I have one that will start fine but, won’t run to far till it dies and I have to sit a minute then start it and it might go 5 feet and do the same thing. The other day it took me 30 min. for me to get back to the house, I was in pasture. I have changed spark plugs and changed gas but nothing has helped do you have an idea of what could be the problem?
Thank you, widowed and upset
Do you have a way to check fuel pressure. Also have changed fuel filter. you get a lot of water in the filters. When you turn the key on you may hear the pump run or cycle , have seen the line off pump leaking in take . sounds like a fuel problem if it starts and runs fine for a short time.
Sorry for not answering sooner, company came. My son did change the fuel filter and it didn’t help. I wouldn’t know what kind of tool it would take to check the fuel pressure. I’m just a woman trying to save money and fix what needs fixed. Can you tell me what it looks like please.
Thank you for the advise, I will check it out tomorrow. Widowed and Upset
thank you, I will check those things.
ok, you will need proper tools . just a fast check turn on and off your key 3 times, to let pump run. Then after the 3rd time turn the key to engage starter and see if it will start . Sounds like a fuel pump issue.
Thank you, I will try that. If it is the fuel pump do you know if it’s an easy fix for a non mechanic? Thank you
Depending on year , and how old of pump, it may need a updated pump and regulator and wire harness . Sorry. They have a special hose clamps also, plus a dealer can check for proper fuel pressure to make sure that is the problem ,not just putting parts on.
Thank you, I was afraid of that. Thank you for your advise. I’ll see what it needs. Thanks
You can check fuel pressure with a regular electric fuel pump pressure gauge. The book says to disconnect the soft line from the rail and connect to the gauge. That works fine.
1 - 18 of 18 Posts
