1 - 2 of 2 Posts
Have a 2013 825i with 400 hours "5000 miles". Noticed on the rear lower controls arms I can see that it has been wearing around the outer bushing nuts. Once I lifted the machine in the air I can definitely move the wheel in and out. Is this a common wear item on these machines and whats the best way to go about fixing it? Do they make a replacement bushing that simply gets installed?
Yes , there is bushings and a sleeve that can be replace. install new lock nut also. This is for the lower serial numbers. You do see it on the front arms on machines used a lot.
1 - 2 of 2 Posts
