he 825i service is based upon hours or time whichever comes first.
Is everyone following this routine? I would replace the air filter based upon inspection and usually based upon driving conditions.
Annually, the net is:
1. fuel filter
2. air filter
3. spark plugs
4. Oil/filter - if this were a car, I would do it every 6 months unless using synthetic. For air cooled OPE, I do it annually - never get more than 20 hrs on them.
5. grease
6. Clean drive clutch - I looked at the tech ref manual and nothing unique on how to clean it. It is just a belt
Every 50 Hours or Annually
• Check brake fluid level.
• Lubricate drive line (two locations).
• Check 4WD front differential oil level.
• Check transaxle oil level.
• Inspect driveline CV boots for tears or punctures.
• Inspect park brake for proper function. (See your John Deere dealer for any adjustments needed.)
• Grease cargo box tailgate strikers.
Every 100 Hours or Annually (whichever comes first)
• Change engine oil and filter.
Every 200 Hours or Annually (whichever comes first)
• Change fuel filter.
• Change spark plugs.
• Change air cleaner element.
• Check air cleaner dust unloading valve.
• Clean radiator.
• Check drive belt condition.
• Check driven clutch wear buttons (625i).
• Clean primary drive clutch.
• Inspect battery. Clean if necessary.
• Inspect alternator belt (825i, optional on 625i).
• Grease front and rear suspension bushings.
• Check toe-in.
• Check brake pad wear.
• Check park brake oil level.
• Check and tighten wheel bolts to correct torque.
• Check/clean spark arrestor if equipped.
• Check and tighten all hardware.
• Inspect cargo box lanyards.
1. fuel filter
2. air filter
3. spark plugs
5. grease
• Clean radiator.
• Check toe-in.
