21 - 25 of 25 Posts
Hi, I’m Jim I have an 825i with the same problem, pin 6 has 12 volts at top and at connector under seat. But pin 3 has 8 volts with key off and 35 volts when you turn the key on. It stays there for 1 sec then something clicks and goes to o. I’m doing this with the fuel pump plug unplugged. If this is the relay, where is it to replace?
I have 2011 John Deere gator 825i I turns over but has no spark. I pulled a plug and it as dry.
I do have fuel coming out of the fuel filter when the key is first turned on.
It happened on Saturday after it was washed and was driven from one building to another and shut off.
It hasn't run since except for about 30 seconds on Monday and has not fires since.
I took out the crank sensor and took it to the John Deere dealer and the mechanic said that if a screw driver sticks to it, it is ok.
21 - 25 of 25 Posts
