I have unhooked the temperature sensor and it makes no difference it is hard to start and runs rough any ideas
So for anyone who still has this problem. The ground sys on these gators suck! Run a ground from the engine to the frame and it will fix the temp gauge reading HOT! I went from the bracket right next to the temp sensor to the main frame ground. Problem solved!I have unhooked the temperature sensor and it makes no difference it is hard to start and runs rough any ideas
