1 - 12 of 12 Posts
Bought new battery thinking the battery was old.
Doesnt take long for the battery light to come on when I turn on the lights. I have a LED bar as well on the roof. If Im driving around and turn off the gator and all lights. Sometimes there is not enough amps to crank the engine and I have to jump it. I also notice that only 2 of the four stock lights work in the front of the utv. I checked fuses and everything seems fine.
If anyone has had these problems or have experience in this I would greatly appreciate a sense of direction. Thank you
2 of the headlights will turn off at idle after a little bit than back on once driving to conserve battery
When you pull the voltage regulator fuse under the hood look for signs of the fuse starting to melt. Had this issue fuse not blown but it will build up a coating on the contacts of the fuse you can scrap it off and keep going. It will overheat from either to much load or a partial ground.
draining
Going to order a new Volt reg. see what happens then
Thank you!
Before you do that have you put a meter on the battery with the engine running you should see over 13 volts at idle and it will increase as you speed up the engine that will tell you if the voltage regulator is good or not. If it looks good have the battery checked.
Discussion Starter #9
yup
I did that..14.3 on idle, as soon as i turned lights on and light bar 10.6.
Sounds like you might be losing voltage to ground. Try pulling the fuse for the headlights and do the same test if it's still doing the same then reinstall the fuse and pull the fuse for the light bar and retest.
Discussion Starter #11
voltage
I will test that this weekend. I installed the volt reg but was unable to drive around due to weather and hunting with the kids. This weekend I will be back up north trying it out and tinkering with it. Thanks for the fuse recommendation...
1 - 12 of 12 Posts
