My Gator vibrates a lot. I noticed that the clutch (secondary) has a small loose as if it was not sitting tight on the shaft. What is the best way to remove the clutch. Could the problem be coming from the engine??? when I rev it up, I get like a knocking sound coming from the engine.
Thank you for your help,
J-P
Knocking sound is not normal and sound like you need to find someone to fix it for you.
Thank you, I will. I saw a video of a AMT626 and it sounds like mine. Maybe this knocking sound is normal or something else...
There is a Facebook group for the AMT that seems very active.
One more things, while I am with experts, all my 4 tires are the same size but two different make therefore not the same height...can it cause a problem with the chains.
