On a new XUV590M are the Fox high pressure monotube shocks worth the extra $412.00?
S Sqdqo · Registered Joined Apr 11, 2020 · 4 Posts Discussion Starter • #1 • 19 d ago On a new XUV590M are the Fox high pressure monotube shocks worth the extra $412.00?
dane · Registered Joined Aug 23, 2012 · 832 Posts #2 • 19 d ago I think like any performance upgrade it all depends on how you intend to use the machine.
2 200mph · Registered Joined Nov 15, 2014 · 1,695 Posts #3 • 19 d ago May want to check what a stock replacement shock is from JD and then consider if the fox shock will last longer.
S Sqdqo · Registered Joined Apr 11, 2020 · 4 Posts Discussion Starter • #4 • 19 d ago I should have stated are they worth it when ordering a new machine
2 200mph · Registered Joined Nov 15, 2014 · 1,695 Posts #5 • 19 d ago Point being if they last longer than standard the cost of ownership might be less and they performance might be better.
