My 625i starts right up in Houston and idles smoothly. As I accelerate it backfires and falters. If I let it warmup at idle for several minutes, then it runs normally.
Any ideas?
Any ideas?
Thank you for the great ideas. I checked the service manual for the 625i and it doesn't appear to have the second inline filter. I had a family member with lots of ATV experience suggest that it might be either eroded spark plugs or clogged spark arrestor. I gapped and installed new plugs and cleaned the spark arrestor with carb cleaner as suggested in the owner's manual and now everything seems fine. I have only run it once since though and unfortunately I didn't run it in between cleaning the arrestor and installing the plugs so I don't know which issue was the exact cause. I guess the odds are that once in awhile the solution is simple!#28 on the diagram
