Hello RSX850 members,
I am new to the forum and a new RSX850 owner as of October 2012. I have had all of the recall upgrades. During this past PA winter, I could not start the Gator and come to find out it is the battery. I can jump start it but it will not hold a charge.
Has anyone expereinced a bad battery within 1 1/5 years or a short that may be draining the battery?
Thanks much for any insight!
DW
Hello and welcome from another new forum member. Although I've had my machine only since April of this year, the original battery was installed in 10/12. After 8 hours of run time my battery went dead as well. I picked up a charger and at 10 amps recharged it to full in about 1 1/2 hours.
Have you made any electrical upgrades? Are you using a battery tender while it sits? Have you tried a recharge? JD batteries are not their strong suit. So if you've tried the above and it still won't hold a charge it might be time to bite the bullet. If you haven't, try a charger on it. Hope this helps.
Been running an Odyssey 925 for the last couple of months. Bolts right in with a couple longer bolts for the battery retainer. Run HID headlight bulbs, 2 HID can lights and an LED light bar. One of the best upgrades I've done so far. Stay away from the JD Strongbox battery they recommend as a replacement!
