Is there some way to remove the battery on a 550/560/590 without removing all the right side panels?
I know this is a super old post, I just purchased a 2013 xuv 550. I need to replace the battery. It seems that I'm going to need to remove some plastic on the side because you can't even get to the bolt that holds down the battery bracket tie down. Any suggestions? Thanks...
I have a '16 560. With the seat raised, I removed the tiedown bolt that I could access. I just bent back the tiedown until I could remove the battery. I slid the new battery back under the tiedown and replaced the bolt. Works fine. Hope this helps.
