1 - 15 of 15 Posts
Is it normal to have any wear on the outside of the cvt belt? My gator had a new belt put on at 7.5 hours under warranty for slapping the belt housing. It still slaps the housing when cold and while washing the other day I noticed the outside of the belt is wearing. It has almost peeled the part number off in 20 hours of use.
How to properly break in a CVT belt
This is JD problem to own. Inform the dealer to resolve as this is not right.
Reactions: rockman47 and jd772
Discussion Starter · #6 ·
It’s a xuv560e. I have had it at the dealer. They put a belt on it and this one is wearing at 20 hours use. I talked to them yesterday and they said send them pictures. I haven’t heard anything back yet.
Can you determine if the current belt part number is correct, per the parts website?
It is the correct number and I’ve verified with 2 dealers parts counters that the number is up to date and correct.
Out of curiosity what is the part number?
Discussion Starter · #11 ·
I also verified that the part number for the older gator of this model is the same specs, it only changed part number due to a new supplier.
I’m seeing the 590e less than -04000 is a different part number and belt length than the 590e 040001-
I don’t see the part number you referenced, I see part M177533 for the 590e greater than 040001-
source
Green Parts Store website
14542
Reactions: 200mph
1 - 15 of 15 Posts
