Lets step back a few posts. I would think any CB would draw more amperage than 1.1851 amps! Thats 16 watts at 13.5v DC. A typical high end reciever radio will draw around 4 amps or more. Thats 54 watts at 13.5v DC. As for the switched or unswitched battery connection, thats your preference. However, most battery manufactures in the US manufacture batteries from recycled lead. Thats lead coming from the dead battery you had in your lawn mower three years ago! Recyled batteries WILL NOT hold up as long as a batteries manufactured with pure lead. Your battery is the heart if the electrical system. Every load source applied should be carried from the battery back to the battery. Not the frame or engine as a ground point. A GOOD electrical circuit has little resistance. Engine or frame connections ADD resistance. Yes i realize these components have need for grounds also. Odyssey makes a pure lead battery that will stand the test of time. With that being said, heat and vibration are the other killers of batteries. Batteries can heat excessively from engine temps or current loads. Also, no one ever does this, but a load that is switched on the ground will typically last longer. The electrons bouncing back and forth on positive side switched loads back up to the switch contact breaks and burn then over time. Reduced contact burns and longer switch life is gained by switching on ground side because the load uses more of the free electrons before they have a chance to burn the contacts breaks.
