1 - 20 of 24 Posts
Ok here it goes. I found a great deal on the RSX so I went with it.First thing I did was sent it to a friend of mine at extreme atv for 2 inich lift looks great,add a snorkel.I have ordered a 4 INICH GEAR LIFT for it.pics to up soon
welcome to the forum.
Cant wait to see the pictures. Dont forget to add the details on the custom work, that's how most of us come up with how we get rid of our paychecks.
Great to hear there is someone on this forum that has purchased the gear lift! cant wait to see pics and hear how it does!
As soon as I can get the pictures uploaded I will
Discussion Starter · #6 ·
XD2311 how did you wire up your fan over ride switch an at what point do you turn it on
I'm curious about the GR lifts too... They're a little pricey but if they work as well as HL says then it may be worth looking into..
Discussion Starter · #8 ·
Just waiting on it to come in an I'll let everyone know how it does lord knows that I am very hard on a bike as our saying goes go hard are go home.got some led lights in last night when I get them on I will post pics. Also I am in the the middle of building a rad an ooilcoler relocate will post pics of that also
used a relay, switch and spliced into the existing wire to the fan.(blue one on the 4 pin connector of the ECM)
Turn it on after I go through a couple of mud holes and the mud starts to harden in the raditor.
Here are some shots of the snorkel I built
Can you give us some sizes/lengths/angle/bends on the pieces that contect to the air box?
Thanks
Discussion Starter · #11 ·
Yes as soon as I can get to the shop an get the get all the info when im finished
Discussion Starter · #12 ·
Had brain fart!!!! When I get back to the house I will get you all that info
Discussion Starter · #13 ·
OK coming out of airbox ia a
CANTEX 2.5 with a rigid nut on the back if it.Then a 2 " cupler fits nice an snug in the 2.5 fitting.then glue a 6"long piece in to a 45 from there a 2" long piece to a 20 then come up with a 20"piece an top off with a 90. all is glued but one piece an that is the one at the air box an I used black rtv gasket maker for easy filter change. IF any of you guys need any more info feel free to call me 318-355-5968
Great info. That gives me a starting point.
Thanks
Discussion Starter · #17 ·
pvc an a few rubber pvc boots
Looking Good!!! Welcome to the forum.
Sent from my SAMSUNG-SGH-I497 using Off-Road Forums mobile app
Discussion Starter · #19 ·
Update on the gator radio an speakers installed,two 18 watt led lights mounted on windshield one 18 wat led mounted under brake light 200 watt amp mounted above brake light waiting on two wake board tubes with 6.5 kickers to come in kenwood radio mounted on front roll cage tube starting to take shape. THE ONLY BAD THING IS THE 4 INCH GEAR LIFT IS IT HAS BEEN ON ORDER SINCE 4-26 AN STILL NOT HERE
521edge, I had some communication today with High Lifter because I am interested in the 4 inch gear lift. They said that it would a few more weeks before they even start stocking it but they have a part number for it. Did you order it from somewhere or someone else or did they let you advance order it? Just wondering. Thanks for your help.
1 - 20 of 24 Posts
