Not sure where to put this
But 2014 John Deere 310sk backhoe
It’s keyless. Has code start
Just happened today no start only click once when you push start button
Batteries are good power to starter 12v +
Bad starter ? Any ideas
Man there’s a lot of wires on this thing
Starter looks like fun to pull
If you don’t receive a response, you might consider posting your questions on Green Tractor Talk.
Green Tractor Talk is a different online forum dedicated to John Deere Tractors.
https://www.greentractortalk.com
Good luck!
It was the positive battery cable looked like new corroded inside but would just let enough juice go thru for the click not enough to turn starter
New starter was 1065.00 glad didn’t need it
Told you never to trust a mechanic.
Mechanics think differently, we tend to replace if it looks logical and its an easy job.
If its not the starter we put it back on the shelve.
Replacing a starter is usually a few minutes worth of time.
Hard to see things through the internet.
Also the state and age of the machine usually gives a few pointers as to the problem and most our clients are returning customers as i tend to see some machines on a monthly or bimonthly basis.
Bottom line, mechanics are the best to work on your machine but the worst to ask a question to
