Discussion Starter · #2 ·
And how fast should it go? Fastest I can get it to run is 29kmh which is only 18mph. I've fitted a new drive belt. The pulleys seemed to work with no load at least. Its a diesel and revs to 0ver 3000rpm. Seems as though it should go a lot faster?
I found this in my photos file, it must've washed off with the pressure washer. Now that I know the model I can see it should get up to about 30mph so I've clearly got a problem. The RPMs reach 3350 so its got to be the belt drive?
Font Material property Technology Electronic device Electric blue
55 km/h and 28” tires and push removed from clutch
Not certain how to interpret this post on your it’s relevancy to the thread.
Can you expanded context?
Ok. This is my last message to forum. Second message was: what is the top speed. I tought i answered to that. Sorry for my bad english, now i think i cant even read correctly.
It’s ok English not the best.
Wanted to make certain if you needed help, there wasn’t enough clarity to do so.
