1 - 2 of 2 Posts
When the warranty expires on my RSX860, I intend to make a few clearance changes. I will be fabbing 2" brackets to add some lift. i also plan to run 30" tires. I've been checking craigslist often to see how often the CanAm X3 30x10-14 tires on 4x137 beadlock wheels takeoffs are popping up and it is often. I plan to run spacers. I know the backspacing will likely be deeper on front so I'll run a 2" front spacer. 1-1/2" would probably be fine for the rear just to give it a wider stance since I'm going up about 4 total inches.. My question is that although the CanAm has the same bolt pattern as the RSX860i, is the center hole going to be an issue. What about lug hole diameters? Or will everything pretty much be the same? Have any of you made this swap?
1 - 2 of 2 Posts
